Marks Web Site
Date:  11-22-2008
Number of Hours:  5.00
Manual Reference:  11-9
Brief Description:  Propeller governor installation...
My brother Bernie came by. After adjusting the control arm position on the propeller governor and trimming the governor control cable mounting bracket we installed the propeller governor and control cable mounting bracket. Following this we installed the oil filler neck and dip stick assembly. Next we drilled the firewall for the propeller control cable pass through and finished up by drilling and mounting the engine control mounting bracket on the instrument panel.
Propeller governor and control cable bracket installed
Oil filler neck and dip stick assembly installed
Engine control cable mounting bracket drilled and installed
